SignUp Now!I have GN1stock stroke kit and billet main caps. So I should be ok? Not looking for more than 600rwhp.
If you know how to tune the thing, sure.
I know that I am on borrowed time, stock bottom end , cam upgraded, cast iron heads ( very mild clean up ) , TE69 turbo, I have dropped a pushrod in the motor again ( winter project - may have wiped a lobe again) low 6.40's in the 1/8. I have contacted a few builders and will eventually go with a stroker kit and new billet caps. Watch your tune as stated above keep it fat and rich.
No way he needs a 72mm throttle body and plenum unless he is going mid to bottom 9's. The stock throttle body will go well into the 10's. He could have it ported out to 65mm, but thats still $$$ spent that coulda went elsewhere. Put a power plate on it, and polish the inside of the plenum. A ported intake is fine, but the bigger TB and plenum is a waste of almost $500. That 72 was made to run with the Champion full race intake...which is not needed until your thinking 8's.I did the stock stroke .02 over. Motor is strong. Instant throttle response and spool with stock turbo. I think the 72mm throttle body, plentium and ported intake make a good combo with what you're doing too.
Well that's def a bogus vendor. As soon as you got 60# injectors...he shoulda said..."you don't need the 72mm." "Maybe grab a chip and Alky kit." I can't speak for them, it's about their bottom line.Yeah he knew my goals!!! Talked to him too many times.
And yeah I could have an alky kit. Even money.
Ok he doesn't need one. If I was on this forum a year ago I would be well informed about many other things, and could have saved myself some $$$$. I never knew we had so many kind turbo buick owners in the world. Thanks to that vendor for selling me something I didn't need. Same vendor sold me some 60lb injectors but didn't bother to inform me or have on his site that you needed a translator for the chip that it came with. I don't blame anyone but myself. But customer service means a little to me. I don't buys as much from him now for other reasons anyway. Thanks for the info coach. Anyone need a champion throttle body and plentium?
