Bobs rare 6
- Apr 11, 2004
What torque are you running on rjc shims with studs? I am running 75# and have a leak on #3 cyl. Also seeping up through bottom stud by #3. Seeping through threads and out of top of nut. Would it be worth re-torque to 85# and try sealant tabs? It seems to leak under boost after I over reved her in 1st when I accidently pulled column shifter into 1 from 2nd on launch at track. OOPS! Just a thought before I pull dr. side head-------again! Thanks, Bob.
