Originally posted by jjkv
Still waiting on a power plate for the new champion intake
john
Originally posted by turbo2nr
Come on, is the new manifold that bad? I have one on order, waiting for intake to be ported and matched to new GN1 heads.
Anytime you plug up 80% of a hole, there is going to be some downside.
If you can figure out a way to change the flow of air, or any fluid, without affecting pressure, you will have accomplished two things.Your not plugging the hole, your dispersing air more evenly, it works, ther's no denying this
Originally posted by PEACHS
The way i understand this power plate to work, is that it limits flow to the rear cylinders. From what i read is that you have to crank more boost into the intake because of the restriction of the plate.
