RJC power plate ?
Just put the plate on and the car idles a little faster.Is there somethiing not right or do you have to turn the idle down after this.Thank You
If you have a scan tool look at the IAC setting, might be high. I think it should be between 10-20 at idle in Park.
Then you can check the TPS. Should be around .42 to .46 at idle in Park.
Maybe you introduced a vacuum leak. Are all those little hoses installed like they were?
Can also check the seal around the power plate by spraying a little carb cleaner around there.
