Rocker Panel Help!!
sheckyZ28
I am currently repainting my '87 GN and I need help with a rust hole I have on the drivers side rocker panel. Is their a company that sells new rocker panels for our cars? Have any of you ran into this problem and if so what did you do to fix it? Thanks.
I found new GM metal. Check out some Cutlass sites as the outer rockers are the same. I found mine from a cutlass guy. The other option is to have bweavy (gbodyparts) cut you some clean ones...
