Of course, it was WARM! I ran 11.4 and 11.5 two weeks ago in the cold. Sunday was a different matter entirely. I adjusted QA1's for soft front and hard rear, dropped pressure in Nitto DR's from 23 to 17.5 and pumped front tires to max allowable of 44 psi. Disconnected one end link of front sway bar.
Did a reasonable burnout (short) and left at ~2 psi boost... 11.9 @ 115 mph for 1st two runs (60' - 2.0 and 2.1). No spinning of tires. Launched straight.
Third run, I left it in 3rd gear and ran 12.2 @ 117 mph.
Fourth run, I built 5-6 psi at starting line and BLEW the tires away!
I have been letting the tranny shift itself (5,000 rpm consistently) and holding boost at 20 psi with 100 octane. I'm getting NO knock.
I MUST work on my burnout technique and find the sweet spot on boost at the line. As usual, the starting line was not prepped for the T-n-T. My son was going to go with me to help with burnout but had to back out at last minute for family emergency. Guess I will sell my Nitto DR's and go with some MT's as that is what everyone has experience with.
Conrad
