The machine shop re-sized my stock rods using arp rod bolts. When I assembled the shortblock I was afraid the arp grease on the rod bolts was contaminated with metal, so I cleaned them off and dipped them in motor oil before torquing them down. What do you guys use on the rod bolt s before torquing and if oil is used, do I torque to the same spec as specified by arp using "ARP assembly" grease. Thanks turbo6man
