Roller cam and lifters
your link isn't working...... can you tell me more about it....... or please fix the link..... thanks
Here is a picture of the info Bob put in his thread. I couldn't get the link to work.
Please tell me everything that it comes with and if you have pics that would be very helpful .... thanks
I'll have to open the box when I get home and take pics.
Since this is a cast hydraulic roller it will not have the bolt in the nose. It is like a stock cam with the cast in gear. Only the billet roller cams have the bolt in the nose.
just waiting on pics and for some reason I can't locate specs on this cam........ do you happen to have the specs on this cam ?????
204/204
.480 lift with 1.65 rocker
109 CL
Anyone? Bueller..... Bueller......Bueller?????
its a 204/204 that I had custom ground a few years back.
Bob,
Would this be a good combo cam for a ported stock head car with stock displacement? Also what springs/rockers were you using?
Thanks, Dan
It ran pretty well in my car. Ported irons on a factory original bottom end. The springs were regular style (not beehive) for a roller cam, I think 130 lbs seat pressure. I was running 1.65 T&D's, primarily because the valve stem heights in my old heads were not even, and I didn't want to mess with pushrods of all different lengths.
Bob
the whole setup was a little bit "clicky" I think, I'm not sure if it was the T&D's or not.
Most people who heard it run said that it was pretty quiet for a roller cam.
Bob
