Roller cam and lifters
Ok I think I will bite here.
Bob, being a hydraulic lifter why did you need adjustable rockers for lash difference did you have a huge amount of variation?
Also I am going to need to get a push rod sizing tool or is there info out there on what I will need for a pushrod to run this setup with stock rockers for now?
Thanks, Dan
the pushrod will wind up being around 8.250 I think. But it varies with the engine build. I would get the checking pushrod, and order
them once the engine is partially assembled.
The valve stem heights were goofed up in my heads by the guy that did the port work, or one of the guys that fiddled with them between the year I had them ported and the year I installed them.
Bob
