As long as you have a 86-87 engine block you don't need the groove in the front cam journal. Just buy some quality cam bearings. I ran into this also when installing my roller cam.
The "109" block has a groove behind the cam bearing to oil both lifter galleys. The earlier blocks did not have this so that was why most of the camshafts out there have a groove in the front journal to ensure the engine gets oil on both sides of the lifter galleys.
On the plus side when I installed the roller my oil press jumped about 5 psi at a hot idle. Just be sure to set the end play clearance correctly when installing the cam.
