roller cam
asto-t
I getting around to rebuild my engine and want to know if the stock valve covers will clear the rocker arms on a roller cam set up. Do I need a spacer
Roller or stock rockers? Stock should clear but rollers will need to be taller. RJC makes an extension so you can use the stock covers if you want to.
stock rockers will be fine. I have used stock shafts with no issues. Used good hardware, arp bolts and I have used the shaft supports.
All seem to be just fine.
Pre load is very important, make sure it is correct.
