I believe that the issue has to do with the installed height and the diameter of the valve springs. Depending on what type of springs you use, I suppose you might have to have the "seat" where the valve sits on the heads machined so the springs will fit properly. But it's probably not something you will have to worry about. I am sure that if you order a cam, set of lifters, springs, pushrods, etc. from a place like comp, they will be able to sell you something that you will be able to use without having to do any machining to your heads. Also, make sure you realize that alot of cam specs are listed @ 1.5 ratio. Stock ratio for the buicks is 1.55, so it may be a higher/lower actual lift than you think it is. Make sure you are clear on what you are getting before you buy it. Just as an example, consider this: my cam is a 487 lift with 1.5 ratio. But since the buick rockers are actually 1.55, the actual lift ends up being 503. I doubt that with stock heads and pistons etc, that you will choose a large enough cam that you will have any kind of clearance issues though, so probably won't need to worry about it. If you go with that 206/206, you won't have any issues to worry about. That is a very popular grind for these cars and alot of people have had great success with it as well.
