Hi All,
Just a quick note to let everyone know that my TTA is now equiped with roller rockers with no modifications to the heads. In the process of installing them I also found out why I blew a head gasket. Before I put my coil pack back on I decided to check the ignition module, good thing, it was gue! Before the gasket went I was having some really strange symptoms on my scan master. I would be driving and all of a sudden I would start picking up knock retard, it would just jump all over the place and I would'nt even be in the boost. I changed the knock sensor thinking it was bad and the condition did clear up, for a while. It started again and this time I noticed that the knock numbers were changing with the o2's at the same time, weird. Evidently, the module was bad and was causing this problem I was seeing on the scan master. I just couldn't figure out why the motor leaned out, now I know.
