turbov6joe
Signal 1 J-12
- May 22, 2002
Are there any 1.65 ratio shaft style roller rockers for the OE heads that do not require modifications to the heads...IE...grinding at the mounting towers for clearance? If so, who sells them?
I had a set of aluminum Harland Sharpe roller rockers years ago and they required me to grind reliefs into the mounting towers so the arm could clear at full lift...don't really want to go there right now with the heads on the motor.
TIA
TIA
