I just acquired a set of used T&D 1.65:1 roller rockers. Are there any concerns I should be aware of, any reason I shouldn't run these? I got them with the intention of just throwing them on the car along with a new set of PAC 1201 springs. I'm running a hydraulic roller cam I got from Anderson Perf several years ago, I think the duration is 214/214. Don't remember the lift. I'd have to go dig through my files to find the specs. I also have aftermarket valve covers from TA Performance that I believe are supposed to clear roller rockers. Any issues I need to consider, or just throw them on and go?
Anything mechanical I should check on these things? Everything seems to move smoothly, nothing seems amiss, anything I should check particularly closely?
