Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Understand "new technology" is available but let's discuss assuming properly installed and working rope seal.
-The purpose of the seal is to prevent oil leakage and keep dirt from entering.
-Oil leakage chances increase when crank case pressure starts to climb.
-99% of crank case pressure is primarily due to ring seal (no PCV installed).
-If crank case psi is reduced with breathers, why would a rope seal not work?
Yes, neoprene seals are simpler, cheaper and easier, but that doesn't make rope seals less effective. Thoughts?
