I want to upgrade my front brakes and would like to get larger rotors, slotted or cross-drilled, while maintaining the stock calipers, 4-piston cost 2 much. Are there any recommended kits?
I want a set that will fill in the space behind the wheel. Is a 10.5 inch diameter good enough, or is there larger. Nothing looks worse than having good looking rotors that dont complement your wheel size.
If you are interested in more stopping power and brake performance, I think this would be more economical:http://gnttype.org/techarea/brakes/12inch.html Although it won't do much for appearance, the performance is much greater. Cross-drilled rotors are a waste of money in my opinion, unless you road race your turbo regal. I haven't done the upgrade personally, but a friend of mine did...if you try it, let me know how it goes, because I may be doing it later.
