VIRGIN87T
More Boost
- Apr 8, 2002
For the past week or so the car has started fine but ran real rough and smelt like it was running real rich when cold(stock chip, thrasher went out). It even stalled on me a couple times driving down the street when cold, and about 50 degrees outside. But when the car warms up it runs perfect. Well today it was running real rough again so I gave it a little gas to try to clear it out and the rpm's wouldnt come back down and just stayed around 2000. Check engine light finally came on, came out to a code 24 (VSS) but the speedometer and all that seem to work fine.  Would a faulty VSS cause this or does it sound like something else? Any help will be appreciated.
  Would a faulty VSS cause this or does it sound like something else? Any help will be appreciated. ).  it would die sometimes after running it hard, then letting out of the throttle,  and sometimes just from hitting the throttle.  i've been replacing vaccum lines, that helped a bit,  reset the idle air controll, that also helped a bit too.  it cleared up a lot all by its self too, i still haven't figured out how it does that.
 ).  it would die sometimes after running it hard, then letting out of the throttle,  and sometimes just from hitting the throttle.  i've been replacing vaccum lines, that helped a bit,  reset the idle air controll, that also helped a bit too.  it cleared up a lot all by its self too, i still haven't figured out how it does that.   The guide on gnttype.org states something about adjusting the throttle set screw, but since this had never been tampered with will I still need to adjust this? Or will skipping this step still reset the IAC?
