I've been experiencing knock that I think is actually phantom knock. Based on the logs I have been running over the past year I note it comes on @ 5500 RPM.
RPM: 5500 - 6000
Fuel: 93 octane
Boost: 18lbs
Timing: 21 degrees
I think it is phantom knock because I retard timing and I still see the knock. I have retarded timing to as low as 15 degrees and I still see the knock. I am using XFI and the knock count is as high as 10 for whatever that means to most. In my book this to high.
Question, where should I start to look for my issue.
RPM: 5500 - 6000
Fuel: 93 octane
Boost: 18lbs
Timing: 21 degrees
