T
talent
Guest
If my engine dies at idle, the rpm sometimes reads 8250 (max my tables are set up for) and the coil is firing. I flip the power off and on and this remedies the problem. I'm using the crank angle sensor in the distributor of an import. I'm using a 6AL box and HVC coil. What can be causing this?
