Thanks guys.
Yes Turbogta1 this is the car that went to  Vegas.
Have since painted car, straightened out the Fiberglas hood, new low pressure hood shocks, added coil overs front and rear, BMR anti roll bar, exhaust work, hooked up GNX style dash, double flow aluminum radiator, new dual Flex-a-lite Fans,  polished and detailed engine compartment, went through brakes added largest made for a 9 inch Ford and new brake cylinders, added braided lines to feed oil to turbos, replaced seeping fuel lines, re-worked line lock hookup. new front rims, rear rims, M/T radials, Moroso front tires, new 5 point harness, shift light, new K&N filters, tinted the windows, lenses, new window felts, trunk seal, painted window trim, new manual master (Willwood style) brake cylinder,  etc.
You guys know the drill, your never done.
