KenB 87 TT
- Feb 7, 2003
Help a neophyte, please.
The car I take care of for an overseas buddy is an 87 TT, doesn't get driven enough due to my paranoia, and always seems to develop new issues.
Thank said, it has a few leaks (Oil (& ATF)) that appear to be $$ to fix.
A shop that builds custom turbo/supercharger applications suggested to prevent an oil leak from recurring at the main seals, to set-up a crankcase evac. system.
Is this necessary on a car that is, as best I know, essentially stock, other than the adj wastegate allowing 19 psi?
I've not been reading here for a while, and I just don't recall such a system being discussed often, is it the wrong approach, or otherwise are mild leaky mains a given?
Sorry if I'm vague, its just the shop has been straight up with me for 4 years on my other car (396 LT1 94 TA) and I've seen some of their custom applications, so are they being way too conservative (i.e. big time overkill) in their suggestion?
And as it appears the rear main needs replacemetn, since I'm not going to do it myself, whats a reasonable labor-time estimate?
