TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Got rid of the 255/60 TA's I was running and now have a set of 275/60 drag radials. I am using 7" Torque Thrust 2 wheels with 3 3/4" backspacing (because that is what I had!) and they just fit. The driver's side will slightly rub when taking an exit ramp and I will probably have my welder notch the area where it is hitting. Pass side has plenty of clearance. Just wondering what to do to get proper speedo reading as I am sure going to this taller tire throws things out of whack a bit. Will this make the speedo read higher or lower than actual speed and will a simple speedo gear swap help. Is it like the older GM cars where you can just pull out the gear and swap it or is there more to it than that? Just to complicate things I am running 3.50 gears! (Ford 9")
