- May 26, 2001
That is the wire for the factory coolant temp sensor modified with a different connector.
The temp gauge in the car uses its own sensor in place of the factory one.
Below your finger in the pic is the ECM temp sensor and that does have the factory connector.
When the heads were reconditioned, they had to be surfaced. The different ported intake did go on, but not easy?
The new cut on both head surfaces did not allow the different intake manifold to seal properly, so it was removed and machined to fit. This is a common condition which requires the intake to be machined when the block and heads have cut, and is always checked during an engine build.
This was not the first time I have encountered this type of issue, especially with unknown builds?
