87GN
Ran fine last week
Stock motor, low milage, just changed pump to double pumper a few weeks ago, that was the last thing I did.
Car will not start easy, and when it does, it seems to be running on about three or four cylinders.
I believe my stock MAF is good
I changed the o2
I put on a new coil pack, and checked wires.
I hear something not right on the drivers side of motor.
Not rod knock (I've had that one before) maybe just the belt tensioner flopping around as motor struggles to idle?
All fluids look normal.
No codes
Would car even start if cam sensor went dead? How about running on 3cylinders? What would all of a sudden cause that? I looked in valve cover and the noise is not really in there. The rocker shaft seems OK at first glance. No smoke from valve covers or exhaust.
I'm using a scanmaster for now to check out what I can.
Thanks for input!!
Ran fine last week
I changed the o2
No codes
Thanks for input!!
