Favian Cuevas
- Jun 26, 2015
well i been running rich since i got this car running everything is stock other than the adj fuel pre reg my readings on powerlogger at normal tEmp at idle are
ecm 13.8:1
maf 12.7 G/C
LV8 44 G/C
TPS 0.42
RPM 750
IAC 34cts
MAP 22.76 kpa
coolant 186.6
intake air 82.6
volts 13.8
o2 0.670
x-counts 247
advance 37.4
injector counts 3.60-3.81
injector duty 2.4%
2 codes 33,34
if anyone can take a look at these an see if you can shine some light on me
ecm 13.8:1
maf 12.7 G/C
LV8 44 G/C
TPS 0.42
RPM 750
IAC 34cts
MAP 22.76 kpa
coolant 186.6
intake air 82.6
volts 13.8
o2 0.670
x-counts 247
advance 37.4
injector duty 2.4%
2 codes 33,34
