Running Rich
motomafia
guys , my car is running rich , i know i just changed my turbo to a larger one injectors t/b chip and so on , just wondering what adjustments i could make to lean it out , iam going through plugs like crazy! thanks
The chip is burned for the injectors right? If so, do you have another chip to try?
Do you have any scan tool numbers - BLM's, O2's, etc.?
Any codes set?
Any vacume leaks?
Is your fuel pressure gauge good? Do you have access to another one?
Stock MAF or Translater? If stock can you swap with a known good MAF?
