Jimmy2wires
- Jul 11, 2010
The car didn't like the cold. Wouldn't idle until warmed up. Started and ran fine once the weather warmed. Started it one morning, rpms went to 2000 and wouldn't come down util put in gear. Dropped to 700 and service engin light came on. Tried driving, ran rough and cut out every time I stopped. Scan showed bad o2 canister. changed that. Drove the car and the scan kept showing codes and then they would show ok. Temp would show 188 then 13, then 250. RPM would show much higher then actual. Hooked up different computer and it showed a bad a/c relay. Changed that. Still rouning rough.
