Running wires from Alky Kit.
RED LS1
SENIOR MEMBER
Just wondering if anyone can point me towards a clear path to bringing the pump harness and tan wire into the car. I haven't had a chance to start wiring anything but i thought I would ask first .
Route along pass side inner fender up under/behind alky reservoir, around heater box, behind engine and then in through speedo grommet.
Thanks. I assumed the path through the drivers side was an option. I didn't know if people were entering through the pass side anywhere to keep the wires out of the engine bay.
I decided to drill a small hole underneath the dash right under the line for Cruise control there's a perfect spot for a hole with a grommet. Worked perfect. I couldn't bare to go through the speedo grommet.
