Runs 2 Rich
Could you elaborate please? Does it do it under boost or idle or part throttle? What is your fuel pressure with the vacuum line disconnected from the regulator?
What Chip, what Ecm, there are a lot of variables and more information as mentioned will be needed in order to help if possible.
2 Rich
I Have A Reds 93 Chip And Trans Plus Fouls Plugs Out At Part Trottle And Boost Plugs Soakedv In Gas Ive Got 65lbs Injectors And A Te60 With Reg Unscrewed
