I see that some guys went with the s10 set up but i havent seen anyones feed back on the geometry of the car after installing this setup does it throw it off or keps it the same cause if its off it affects the steering of the car and the handling
It doesn't change the spindle height or move the tie rod location, I'm not sure of track width changing... but either way, with the first two parameters the same, you won't have much of a difference in handling.
no problem. The brakes are huge (and the whole setup is quite heavy). I don't have it on my car yet. Though I can't give an accurate "before/after" as I will be going SC&C stage 2 in the process...
