SignUp Now!I take into account the pressure drop with my IC at what 4 #s (dutt IC) my gauge is reading 26#s so i figure im really at 22#s
pulls like a mule
If your boost guage is connected to the intake.. then your running what you see. If your boost guage is connected directly to the turbo.. then you have a guess as to what pressure your truly running.
You can hurt a motor at 15 PSI boost and a street chip.. example pull the hose of your fuel pressure regulator and run 15 PSI boostSo safe boost is only as safe as the attention being paid. That is why knock monitoring is so critical in keeping bad things from happening.
Suggestion.. I dont like anything tied into the MAP sensor line. If you have a boost guage, tie it off the front port that goes to the charcoal cannister behind the alternator.
The reason is if the line to the boost guage blows off.. pops off.. has a leak.. etc etc etc.. you will drop pressure to the 3 bar MAP. If you drop pressure to the 3 bar.. the alky system will put out less alcohol which can lead to bigger problems.
What I get into the habit of doing is run a vacuum hose from the nipple on the passenger rear straight to the 3 bar MAP. And then put two zip ties one oon the MAP and one on the tube. This makes it bullet proof.. pretty much.
I know its typical to get the boost guage connection of that port.. but if you look at the bigger picture.. you'll understand why I post this.
AND.. run a new hose from the metal tube to the fuel pressure regulator.. same deal.. zip ties.. you cannot afford to blow that hose off.
Hope this helps.
Julio
What's a safe amount of boost and a turbotweak chip, 23-5 ??
Hope this helps.
Julio
