ITEMS FOR SALE!!!!---SBF/SBC/BBC/BUICK GN PARTS AND MISC ITEMS all prices do not include shipping,some parts nego.,I have listed the part #’s I could find so most of your ?’s could be answered by looking them up! I may be reached @713 553 0404 or ryanfoxmosley@buickturbo.com pictures may be seen @ ryanfoxmosley.com and i can send more of a particular item if interested thanks!(all items used unless noted)
FORD ITEMS
Custom comp grind out of slaters car (solid roller) 271/281-731-741-110 (new)
Comp roller lifters p#lca-838-16
Comp pushrods(3/8)—p#7908 (8) and p# 7951 (8) cam,pushrods,and lifters—300.00
Moroso double bar stud girdles 302-400 clev.—100.00
Crane 1.73 rockers—100.00 ALL FOR 450.00
Motorsport balancer p# fms-m6316a50 int/ext bal 150.00
Eagle esp h beams 6.000 p#esp-6000b3d w/arp bolts perfect shape—200.00
(10)je pistons w/childs&albert rings(standard) (8) used 2 new 4.040 bore w/ wrist pins—200.00
Tall ford motorsport valve covers-1 has small crack (fixed) no leaks 75.00
Roush motorsport intake p# m-9424-4351 jet hotted w/ spacer for dominator and gaskets ported by lump 300.00
1966 mustang grill mint cond.---150.00
Wolfe lid for fox body hatchback (new) p#mwol430-- 90.00
Ford motorsports Cast iron carrier for 9 in. (new) p#m-4141g ---100.00
Ford motorsports Daytona pinion support (new) p#m-4614-b 75.00
9 in. complete build kit (new) p#ra-313--75.00
Motive gear (new) p# F9-350 350 ratio gear 125.00
91 302 block std bore 30,000 mi bare—150.00
c-4 just out of fox body w/ poly mount (new) works but ready for re-build—100.00
super comp collector headers and flow master collector mufflers—just jet hotted(not run) for a Yates style head---350.00
(2) lx/gt rear covers for hatch grey excellent shape 25.00 ea
R-351 block 4.040 bore (fits the je pistons above) 2 sleeves if interested will p/u from machine shop has been magged and pre. Tested 700.00
NEW subframes for 03 cobra all there just need paint—100.00
CHEVEROLET
Gm crate motor 30,000 mi heads and intake are off but motor is complete and was running 400.00
BBC crank 0.10/0.10 GM w/ flex plate 100.00
Bbc gm rods 103’s w/ pistons 50.00
72 camaro tail lights lenses good need new gaskets---75.00
Moroso bbc anodized red valve covers w/ t handles p# mor-68-012—30.00
Weiland bbc elec. Water pump p#wnd-8218-194 w/ neck also 100.00
Crane lifters,cam(solid flat) 260/260-650/650-108 and pushrods(3/8)---150.00
1 wire alt. (bbc) works great 100a output 50.00
BUICK GN
Stock gn drive shaft w/ hd u joint—50.00
Powdercoated/engraved gn valve covers (CPP) customs-150.00
Mini starter for gn (new) 100.00
Set of (4) 3 way adjustable comp engineering shocks 20-30 passes (fits all g bodys) 75.00
Stock gn intercooler-excellent shape—75.00
CC1 hyd roller perfect (1500 mi) 221/221-525/525-112 100.00
STAGE 1 BUICK MOTORSPORTS PROTOTYPE BLOCK IN THE CRATE 3.8 bore 8 bolt heads comes w/ extra splayed mains-1000.00
Conley knock detector –20.00
Kirban knock detector—20.00
Stock t-type rims w/ good rubber good shape!—200.00
8.5 10 BOLT 28 SPLINE mosers,c-clip eliminators,spool,new Richmond 3.90 gear,summit girdle,s-10 wheel cyl.,brakes,polyurethane bushings all new bearing and assembly kit ---800.00
8445 stock buick heads-need freshen---75.00
MISC. RACEPARTS
Mallory 5 port regulator (return style)( 1:1 regulator if desired) p#650-4300m—100.00
(2) Mallory 140 pumps p#maa-4140---100.00 ea
(2)Mallory 140 filters P3 maa-3140—25.00 ea
Mallory 110 p# maa-4110---40.00
MOSER light wt drum assembly (new) for big bearing 9 in. p#6005—225.00
Universal drive shaft safety loop—20.00
Autometer universal fuel sending unit p#3262-----40.00
Summit tubes (new) 26-29.5 tire w/ 8-9 in. of tread p#sum-710001 60.00
WELD pro stars 15x8-4.5 bs 4.75 bc et streets 28-10.5 wheels and tires have less than 10 passes---------375.00
B&m frame mount oil/trans cooler (new) 20.00
B&M mega shifter type console (new) 20.00
Alum.27x19 rad. (new) 150.00
Quarterstick shifter w/ shiftnoid p# bmm-80842—75.00
Universal stainless steel radiator hose kit (new) p#57307 poslished caps---60.00
FORD ITEMS
CHEVEROLET
BUICK GN
MISC. RACEPARTS
