For Sale many items A
Kidding in the modem. It’s just that every time I want to put dibs on a part someone else has a fib on it. Which is cool. It’s my slow response not the modem. But do you remember how slow they were. Remember downloading porn and took hours? Only to take second for the money shot. Just saying. Lol
I'll take or next inline for:
+) - Casper Coil Hot Wire kit, New 102087 50.00
+) - (1) "Coach" no sag bar 35.00
+) - Power Six Night Light 25.00
OK, one of the bars are still available along with the two other items. Will work on a total need zip. Or were you picking them up can send pics to email or text ?
Yes I left you a vm... I will be down BG.. I just seen someone else asked for it before sry I missed that post. If he doesn’t buy it let me know
Not able to pick up, ship zip is 76065.
Interested in GN blanket, if its still avail.
Send pic(s) to: thompson_hays@msn.com
Thx
Do you need any more pics? With the blanket and swag shipping we are at 175.00 F & F to lower 48
PayPal : gmkendall@swbell.net
Let me know
Thanks , Austin
Hello, just sent you a e-mail on the NOS mass air flow sensor and I am going to pass.
Thank you for your time.
Starting a long list of items that are for sale. All items are priced without shipping. Will be at GS Nats this month, items purchased could be picked if you or others plan on attending,a lot depends on room in the suburban. May need to put wife on roof ! PayPal to Friends or Family or add 3%. Can be reached at 405-831-5195. Trying to keep pics to minimum using group shots, detail pics can be sent if requested. Note this board is limited to only 10 file attachments Text or email are options if needing more info on items. If requesting pics use email if possible. AWKENDAL@SWBELL.NET
4- GM NOS T-Type wheel centers 25518704 New not repo 300.00 set
4- GM NOS GN wheel centers 25525651 New not repo One box opened for pic 275.00 set
GM NOS Mass Airflow Sensor in GM box 25007866 300.00
GM NOS Intercooled emblem 25526372 New in GM bag 35.00
3-GM NOS GrandNational emblems 25516222 New in GM bag 100.00 ea
Kirban GN Palms silver token 50.00
GM NOS LEFT door handle 20454213 In GM box not repo 75.00
GM NOS Delay Relay 25527402 In GM box 150.00
GM Power Master pressure switch NOS 18038508 100.00
86/87 steel vacuum lines good condition 50.00
Kirban vacuum block #6796 Used 30.00
Kirban billet oil filler/breather early production full body used 30.00
GM NOS temp sender 12146312 New in box 30.00
BstC Boost controller New 75.00
Break out Harness Plugs into car computer custom built 100.00
60# injectors pulled to put in 80#, all ohm good 175.00
5 Driver quality T Type wheel centers, usual missing teeth, some better than others 25.00 ea.
Kirban Power Antenna repair kit KPP 7433 New in bag 70.00
Stock Turbo car fuel pump hanger nearly new Deatsch Werks DW301 pulled for double pumper 200.00
2- "Coach" no sag bars, new never installed 35.00 ea.
Set Gray Sun Visors New in bag. PUI 78GVC00 60.00
SBC Foam Mock Up block and heads similar to Summit PYP-2044 to big to bring to BG 250.00
GNX Style Kirban wheel early production (USA) some use, near mint 250.00
UMI Upper/Lower front control arms 303133-1 Black has hardware New in Box still wrapped 850.00
Wilwood Rear disc brake kit. 140-7141-D, E brake option 10/12 bolt small bearing TurboBuicks 650.00
Sway Bar rear after market 1.38"dia. 24.25lbs 150.00
Sway Bar front 36 MM hollow, 14..5lbs powder coated have some hardware 150.00
ShockWave Air Ride kit partial relisting, price drop can send info Was $750 500.00
Knit GrandNational blanket New in bag from GS Nats vendor in past? 50.00
Power Six Night Light see pic 25.00
Buick Motor Sports XL Black T Shirt New in bag, Chris Custom GM License 20.00
Hallmark GSX Christmas ornament New in box. Car is die cast marked 2014 20.00
Front Grille 1986 used okay has crack near top hard to see can send detail pic 75.00
Front Grille 1987 used nice, no apparent problems has Buick emblem 150.00
Exhaust manifolds used crack fixed if needed, Per Side 50.00
Front air dams GM OEM, L & R New out of box some shelf ware 185.00
StageII Timing Cover 25500169 used, OK, some etching in water area 100.00
StageII Timing Cover 25500169 NEW never bolted on apparently 200.00
StageII Intake 2550029 bolted down use very little carb holes helicoiled 150.00
Fast XIM controller & LS 1 Harness new never used open box 3013112 500.00
The Kirban power antenna was miss priced at 70.00 SB-----------------------50.00
I talked to you a few nights ago if you still have now maf at BG i’ll take it. Let me know where you’ll be an what day you’ll be there. I don’t want to ship it
