SignUp Now!DB ,Sorry I was getting in the shower to get out the door for work and thought of a bunch of things that should have been included...Dusty Bradford said:First of all
HP goal???? That will be the starting point. I can give about all the info you need tomorrow night.
daniel said:dusty, i have an 87 we4 i am going to go turbo sbc with it. i have a 9:1 comp 377 with brodix track1 heads. i am thinking about going with the holley stealth ram and a fast system. i have been reading posts on turbomustangs about guys using corvette c4 headers and building pipes to a flowmaster y pipe then bolt the turbo on there.i am thinking about using the 4276 turbo.do you have any suggestions on this setup as far as headers, injector size or any other suggestions you have will be greatly appreciated.i am wanting around 800 horse power or whatever it takes to try to run a 5.99 in the 1/8.thanks in advance for your help.and by the way you have an awesome car. thanks, daniel
Post a link so we can see these headers/manifolds ....thanks :wink:daniel said:dusty, thanks for your help. i am not sure about specs on the 42/76 or any other turbo. it was a suggestion from one of my buddies. the c4 headers are like a block hugger. i seen pics of guys using these headers turned upside down but i did not know if you knew anything about them. thanks, daniel
bandaid, sorry but i am computer illiterate and dont know how to post links or anything for that matter. i just did some searching on turbomustangs.comBandAid said:Post a link so we can see these headers/manifolds ....thanks :wink:
dusty, thanks again for your help. i think i am just going to try to find someone to build me some headers. do you have anybody that you would suggest. thanks, danielDusty Bradford said:O.K. I wasn't thinking about upside down. That should work also if other's are doing it. Just look for the thickness of the flanges and tubing. I like at least a 3/8 flange and 16 gauge tubing. A thinner flange will work but might run into sealing problems.
dusty, thanks again for the reply. i am going to call a guy named joey bell out in woodstock and see what he can do. i know he is real big with the mustang guys out here. if i dont have him do it i will give parker chassis a call.and i am also going to look into an 88mm turbo like you suggested. thanks, danielDusty Bradford said:With you being in Dallas there's probably 3 chassis shops within 30 minutes of you. I highly recommend Parker Chassis down in Columbus though. He did a great job on my roll cage and Richie Kibler took his car to him from North Carolina for headers and crossover along with some other things.
