I'm rebuilding the engine in my 1987 3/4 ton suburban. It has a 350 TBI engine, and I was wondering if anyone on here has messed with TBI before. I would like to put a flat top piston and run .040" piston to head clearance to take advantage of the quench in the closed chamber head. This will raise the compression from 8.3:1 to 10:1. I am a little concerned that may be a little high for an iron headed engine that will be used for towing occasionally. I have considered running a "computer compatible" camshaft that 206*/212* that's around 10* more to bleed a tad of the compression off, and lowering the thermostat from 195 to 180, and only running premium gas when towing.
Do you think this is too much compression?
