hmm maybe I'm having a brain fart, but isn't kpa a measurement of manifold air pressure and not engine load? As 100 kpa is an absolute outside pressure, 0 psi on a vac gauge, or close to WOT on a NA engine.
Is this for setting up wideband AFR tracking on the Gen2?
I have the AFR tracking set to come on around a minimum of 2200rpms and about 112 load LV8. From looking at DirectScan recordings, the load is usually above 100 by as little as 6-7 psi of boost so I wanted my alky to be engaged by the time the AFR tracking kicked on.
