Scan master 3
sscamino
Is the update to scan master 3 out that enables both computer and scan master 3 with FAST 2.0 both to be used at same time? Also is there any way I can monitor fuel pressure on scan master 3?
you dont need to do anything with the scanmaster to use along side a laptop but you do need to load your XFI with the 2.05 flash which enables a second comunication port and then you need to wire the scan master to the second port by adding some pins into the XFI connector
see this http://turbobuick.com/forums/threads/new-xfi-2-05.410268/
in the performance ecm forum because you will be adding some new tables with the 2.05 upgrade and those tables need to be setup
for fuel pressure youll need to speak to turbobob about flashing the SM3
