Scan master picking up knock
Chris gn1
I was installing new chip Tt 110 race 24 degrees of timing. After install I noticed my TPS was a little high .48-4.80, I ajust to specs on chip sheet. I was in park reved motor to about 4,500 rpm and showed 7.1 knock. Did it again it jumped to 13.1. (I have 110 race fuel in car). Drove the car no knock was present. You think it's becouse no load on motor and lots of timing it caused to show knock ?? I hope nothing going wrong with motor
i will only say this once
do not rev the engine with no load in park ..there is nothing to prove and all you will do is run the risk of seizing a wrist pin
the chip is set up and acts different when it thinks you are in park vs when you are in 1-2 , 3-4 gear
