Scan Master #
BOOSTD1
1986 Gn With Fp Reg
Kn Filter
Hotwire Kit
All Rest Stock
02's 505 Mil
Af 05
Lb 36
Bat 12.7
Int 128
Bl 105
Cle 187
Ats 131
R 750
Tps .46
Iac 44
Cc 31-250 Jumping All Around
All Taken At Idle
Anybody See Anything Goofy?
you bat is low!youre bl is low and youre iac a bit high...make sure you alt is good whenb you turn key on engine off does youre bat light come on on dash? also you bl is low which means is pulling fuel (to rich) what youre fuel pressure set to?
the stock set up had problems getting the right voltage to the pump which itself is not that great!!! get a walbro 340 and a hot wire kit this are the first mods to do to a stock set up...also look into youre charging problem:biggrin:
