Carolinaturbot6
Pride. Freedom. America
- May 24, 2001
Could someone just verify something for me please. My OTC4000 has been showing me up to 10 degrees of kr while the recently installed Caspers knock gauge shows zilch. I sent the gauge back because after testing it, I assumed the gauge was bad. A new one was sent to me. I hooked the new gauge up, & I've got the same problem. I spent today making sure I had run the wires correctly & such. I have power to the gauge via the green power light comes on with the key on. I touched the power wire connection & the sender connection (yellow/black stripe) with a safety clip like instructed to test the gauge. Key was on. I even tried it with the car running at idle. The gauge lights should light up while doing this. Still nothing. I checked my connection at the ecm, & it is correct. Now, seeing how my OTC is hooked up to the diagnostic connection under the dash & my gauge is ran straight to the knock sensor signal wire (yellow/black stripe), is there ANY way my OTC can be detecting this much knock & the gauge detects none? Can the gauge somehow differentiate between REAL knock & False knock. I tested the gauge how Caspers instructed. I would really appreciate some help on this. Thanks.
