Scanmaster and Fuel Pump
DavidM
Yesterday I re-wired my Dual Intrepid Fans to run off a toggle switch. Power wire is connected to the battery, ground wire is grounded to radiator support and toggle switch is relayed under the steering wheel. The fans are working just like I wanted them to. I pieced everything back together and went to fire up the car. I noticed that the fuel pump was not priming up and the scanmaster turned on for a second and then shut off. I retracked my steps to ensure I didnt knock any wires lose while installing the toggle switch. I looked at the wires from the fuel pump to battery and they are all in place. Is there something else I should be looking at? Maybe a second relay or fuse? I didnt have fans installed for a couple of days and everything worked like normal. The fan wires are not interrupting with anything else other than maybe its drawing too much from the battey source? What are your thoughts?
David M.
