Scanmaster Code 32
t3intercooled
K boys, I am going racing on saturday in rock falls, and need any immediate advice as to what happened so I can fix it by then.
My scanmaster gave me a malfuction code 32 whcih sad bad or unplugged egr module or solenoid. Now My manual said code 32 to the ECM is the bad switch which i guess is in line with the EGR. First how easy and what is the process to replacing the switch, also where is it located, second if I race with it it not working order will it hurt my motor. Any help will be greatly appreciated. Thank you all in advance.
Brandon
Located on the driver side of the intake, check your vacuum lines going to it.
Ron
