well I have a scanmaster and a knock gauge(which usually does nothing),I had all but tuned all my knock in thrd out then the weather cooled off and I put my 265/50's on the back,Now I start getting knock in third gear after I have been driving it around a bit.did not know if it was cooler air,tire size...?My blm's are always around 138-146 atWOT,also my o2 with the knock are usually 790-820,According to the scanmaster numbers it is not running lean and my fuel pressure is around 45psi.My boost has been turned down to around 15,usaully I am not getting max boost when the knock starts,only 10psi last night.I just don't know if the intercooler heats up or maybe my coolant temps are too low(usually around 165-175)
