Scanmaster normal ranges?
I just installed a scanmaster 2.1 on my stock 87 Gn. I'm trying to determine if the readings I am getting are within normal range. Is this info available somewhere? I tried a search and I find bits of info here and there, but nothing all in one place.
High boost at .035 gap? :eek: Makes me question the whole chart
'High' is a relative term.... I think the implication there is, say, 20-21 psi as opposed to the stock 16-ish... and I believe the primary intent of that tidbit is to advise the use of a colder heat range plug (R42 vs. R43) if upping the boost a bit... a tight .035 is the norm under those conditions....
Thanks. Everything looks pretty normal except my BLM is a little high at 136. Is that something I should be concerned about?
it's a bit high...bump the fuel pressure up a pound or two, and that should bring it down... if not, post back...
