Scanmaster Numbers
ecna
Guys,
Just getting my car ready for Englishtown tomorrow. I've changed a few things and I'm wondering what you think of these numbers. They are all at idle except TPS (both ways)
02 750 or so
AF 05
L8 37-41
INT 128
BL 127
CLT 170
ATS 128
RPM 825
TPS .44 (.38 not running key on)
IAC 30
Thanks,
Eric
Those numbers look fine to me. Is the car basically stock? You should also check TPS at full throttle as well to make sure its at or above 4.5v. If you could post some numbers from a full throttle pass then we/you would have a better idea of what you really need to know for the track. Number from a datalogger like directscan or powerlogger would be best if you have one.
I can't find my scanmaster booklet, is there a memory mode you can get to other than just O2s and KR?? so you can keep your eyes on the road at WOT blast? then recall all #s
I think it only logs the peek numbers from o2 and KR. you can find the instructions at fullthrottletech.com
IAC looks a little high, but really, i wouldnt worry much about it.
At idle, it should be around 10-20. Around that ball park.
