scanmaster/ powerlogger / wideband help
jcawley3
does anyone live close or within an hour of Augusta, Ga that knows the Scanmaster and Powerlogger GOOD.
This thing is killing me. I did the upgrade on scanmaster and connected to pl now not working. Also need some help tuning.
I have read and read and posted but still nothing. thanks, John
Not an hour away, but if you bring it to the event in Burlington here in a couple weeks I'm sure there will be plenty of people there to help...
K.
Not in GA but I can suggest couple things.
1 the cable between the I/O card and the PL. Make sure none if the pins are bent and it's plugged in right.
2 remove the pl from the ecm and go over the connections one more time.
3 check the chip you installed in the scanmaster for bent pins or pins not in the socket.
HTH
RL
ok. I got it fixed... thanks Eric! .... however I catching hell tuning it. I'm trying to read up and learn as much as I can... but I just dont understand what the number mean.... I'm getting better but need help for sure.
What are the dates in NC? Got a baby on the way and its getting close...
