Jul 9, 2005 #1 K KEVINS87T Member Joined May 2, 2004 Messages 104 air temp sensor is flashing hot.even does this when car is cold.could this agffect the way the car performs?
Jul 9, 2005 #2 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 Depends on the chip whether it uses the ATS for adjustments. Truly... fix/replace the sensor/wiring. Its the sensor by the airfilter. Either its unplugged or missing. HTH
Jul 9, 2005 #3 K KEVINS87T Member Joined May 2, 2004 Messages 104 response Razor said: Depends on the chip whether it uses the ATS for adjustments. Truly... fix/replace the sensor/wiring. Its the sensor by the airfilter. Either its unplugged or missing. HTH Click to expand... do you know the part # of this sensor?
