trading t/a
I'm Angry!!!!!
- Aug 6, 2001
To fill you guys in. I was having diffuculty trying to tune this thing. My blm's are always in the 90-103 range at idle, but my o2's cycle between 50 and 800 mv. The int is around 124-130. My setup is in my sig, Trying to tune with the extender has been diffucult but is getting better. I thought I was having a lean condition up top cause the o2's always read between 350-580mv(but no knock). My settings consisted of: base spark +8*/wot -10*/base maf at setting 3/ wot maf 14% rich. Today I thought I'd screw with it a bit. I changed the base spark to 0(no change)/wot spark to -6*/base maf and wot maf same. It feels a little lazy down low, blm's cycle between 100-114(114 mostly), my int is around 106-122. I cant see anything with the blms or int at wot cause they lock at 128 past 1/2 throttle. With the previous setting for some reason I couldn't buils more than 16 pounds of boost with the cutout closed, now with the new setting I get 20 psi with the cutout closed. Only now I'm getting .7* of knock. Not too bad I guess, but I like seeing no knock at all.
Well to my question finally, If the scanmaster is reading 30mv on the o2 does it mean it is 1030? I did two wot blasts and got 13mv and 30mv with only .7* of knock each time. With the old setting I would get 2.9-4.0* of retard. It definately feels stronger up top now(didn't think it was possible cause it pulled like a raped ape up top before, now it just rips the tires loose in every gear). At the track a few weeks it ran the 1/8 at about 82mph but at the traps I ran 114mph. Does that seem like a lot of mph to be making up.
Thanx
Pete
Sorry for rambling on.
By the way my fp is set at 45 psi Line off
Thanx
Pete
