helping a friend, car is an 84 GN with the conversion to 87 ecm, MAF, and coilpack/ign module.
Problems are two fold, Battery readings on the scanmaster are low. Like 11.5-11.9-12.3 yet on the battery of the car it reads 13.9-14.0. Also if you put the car on bat and do a run, it blinks and goes to the main O2 screen. Or any other function. It goes to the O2 sensor reading. Will show KR while decellerating yet the motor has no kr. And its intermittant, yet duplicatable under different circumstances. There is no low fan relay.
How does the scanmaster detect voltage? I presume its of the aldl line. But the ecm at its man power connector has 13.8 volts.
Car is cutting of at high boost as well. Like if there is an electrical problem. Grounds were added from motor to chassis. Battery to chassis. ecm to chassis using heavy 8 guage wire, same problem. Alternator was replaced as well. Grounds redone on the scanmaster. Replaced ecm, MAF, plugs, wires, battery, alt,.. out of ideas.
So how does the ecm detect voltage to display those lower numbers?
Any help would be appreciated.
